MB's latest modification thread...
Old Jan 22, 2012 | 12:38 AM
  #681
mr-pitts's Avatar
If you go "big" as in a 2.4 or bigger you will have to reduce your redline. Whilst researching my turbo build I was informed that once you stroke the crank( so to speak) that the piston speed is so high that the wear on them is unacceptable.
This is one reason I didn't go for a stroker crank on mine, although mine is a 2.2. This has absolutely nothing to do with the quality of the component it's purely down to the physics.But you probably knew that already Mark.
Old Jan 22, 2012 | 01:09 AM
  #682
MB's Avatar
MB
Member
Yep there's no way I will stroker the car. Reliability is a must.
Old Jan 22, 2012 | 08:32 AM
  #683
martin j's Avatar
Originally Posted by MB
I'm looking into some options to take it a bit further in the power side
Think a cage might be in order too.
A cage in the car, or.................. one to keep the car in?
Old Jan 22, 2012 | 01:37 PM
  #684
Kitesurfer s2000's Avatar
So a S/C kit then Mark, resistance is futile
Old Jan 22, 2012 | 01:42 PM
  #685
MB's Avatar
MB
Member
Never!
We shall see but now i've got the truck (to maybe tow it) i'm tempted to go balls out modifying it...
Old Jan 22, 2012 | 01:45 PM
  #686
lovegroova's Avatar
Never!
Excellent, even more parts will be available in future at knockdown prices - keep egging him on chaps!
Old Jan 22, 2012 | 01:51 PM
  #687
MB's Avatar
MB
Member
Exciting stuff like window glass and interior trim if you are interested
Old Jan 23, 2012 | 12:49 PM
  #688
MB's Avatar
MB
Member
Something which has been on my mind over the last few months is safety stuff. The concern is something like mechanical failure / blow out at high speed or spinning on the coolant dumped by some dodgy GT3 I've seen a few incidents on video lately to. As my old man tracks the car too, I want to make sure it's safe.
I have bucket seats in the car, which are quite low, but am using OEM seatbelts. This worries me a bit, although the seatbelts work as per OEM seats.
What i'd like is proper harnesses in place, but safely so, such that in the event of a crash the bar doesn't get pulled off if the seats decide to move.
What i'm a bit wary of is welding stuff in which isn't reversable. And not sure I like the idea of a full cage as it looks a bloody bugger to get out quickly if you need to.
So I guess it's a half cage like this:
Or is there another solution to safely use a harness?
Requirements are: (stolen from AE on another thread)
MSA regulation ideally
Roll hoops and Glove box stay
Bolt in
Hard and soft top compatible
Harness bar.
Old Jan 25, 2012 | 10:04 AM
  #689
MB's Avatar
MB
Member
Any views on this?
Old Jan 25, 2012 | 10:38 AM
  #690
mr-pitts's Avatar
What's the one Razz fitted?
