MB's modification thread...
Old Jun 21, 2010 | 03:21 AM
  #641
Dixon Motorsports's Avatar
Just go for CT supercharge, is the easiest way to get power! stock setup is already 300bhp and with the smallest pulley you can get 450bhp.
Also stock setup comes with 6 months warrantee, I don't think any other Supercharge company in the world can offer this.
Old Jun 21, 2010 | 03:34 AM
  #642
MB's Avatar
MB
Member
Sorry Mikey, I get what you are saying now. I will look under the car alter and see if there is a nut onder there. I thought you meant a blind nut.
Hi Dixon, i'm not a fan of the Comptech though mainly due to the size and weight of it over the front nose. I just prefer the Rotrex as it's lighter and a bit more compact.
Do you have any plans to track / race an S2000, out of interest?
Brakes are spot on now i've turned them round
Old Jun 22, 2010 | 09:34 AM
  #643
The CT kit is not heavy at all, probably same as the Rotrex and also SOS have a optional supersize radiator for the charge cooler, you get cooler air temp into the engine = more power and more reliable!
Yeah I am selling all my race car and shell now, gonna be a S2000 race car soon. Will let you guys know when I got the car!
Old Jun 22, 2010 | 09:54 AM
  #644
eSeM's Avatar
IIRC we compared the weights of each in the past and the Rotrex kit was around half the weight of the Comptech.
HTH
Old Jun 22, 2010 | 11:50 AM
  #645
s2konroids's Avatar
HTH
I always believed the CT kit is heavier than the Rotrex but by how much? 10KG's?
MB, keep working on the guns . No guns equals no huns with buns .
Old Jun 23, 2010 | 04:17 AM
  #646
RedUn's Avatar
Originally Posted by MB,Jun 19 2010, 06:09 PM
Adrian, no plans on that front atm. I'd like a Mugen wing but it wouldn't fit with the stealth ethos of the car I've got a feeling that I might go silly with it before long though In which case it would get stripped etc! But I have to remember it's pretty much a perfect compromise as it is, and if I spend any more I might as well have bought an old GT3
Redun, if feels good where it is for now, but I might experiment. It goes too low the slider mechanism won't work but oddly it would probably solve the porblem of the bolsters hitting the tunnel, as they would drop below it. I think the slider bar can be bent to suit though.
I've looked at old GT3's, most of them are dogs and the running costs are more than double that of the Honda for not much more speed on track unless theres a big straight but then thats expected.
I have mine on the lowest which means I can't use the slider, not a problem for me as theres only me who drives the car.
You have a PM btw.
Old Jun 25, 2010 | 12:08 PM
  #647
MB's Avatar
MB
Member
Agreed, you pretty much have to assume that any GT3 has spent a lot of it's life being hammered
Ok a question for you brake people...
My Dixcels were great at combe, which is a heavy braking track. But I noticed they were generating so much heat I couldn't touch the wheels. Very very hot. But more concerning is they started to rumble after a couple of laps abuse. I hope they aren't warped. Seemed ok on the way home, just when they got hot.
Anyone else found this?
I might get a clock on them next time i'm home and just check they haven't warped.
Old Jun 25, 2010 | 12:58 PM
  #648
lovegroova's Avatar
I've had some rumble in the past, but it's usually gone away on its own.
Old Jun 25, 2010 | 01:08 PM
  #649
All you need to do is brake harder, R01 pad surface won’t melt until around 200 degrees, if the pad deposit on the disk is not evenly lay out, you will get judder from the non even disk surface.
Dont worry I am 99.9% sure your disk is fine, you just need to brake harder and later, once you got them bedded in properly the temperature will stay much lower.
Dixon
Old Jun 25, 2010 | 01:09 PM
  #650
MB's Avatar
MB
Member
Harder - I like it Dixon I can do that. Will let you know how I get on, but I was impressed with them.
How often would you change brake fluid? I'm on Motul 600.
