Meguiars three step process
Step 1 - Deep Crystal paint cleaner
Ok, so I cheated on the first step - perhaps my downfall but i dont think so.
Washed the car with a mild washing liquid solution then gave it a good once over with autoglym non foaming shampoo.
Pretty sure this would have got it as clean as the Step 1 paint cleaner. just wasnt in the mood to pay
Anyone tried this new autoglym deep shine shit yet?
http://www.autoglym.co.uk/agnews/newspages...UDS_Launch.htm#
Sounds like you had some moisture in the cloth/pads when you removed the crystal polish; it's a real pain in the arse to get those smears off.
Done right the meguiars stuff is good, but if you mix the polish with even the smallest amount of water when applying or removing from the panels you get the smears.
It all takes to long to imo, I need something that looks as good, but doesn't take 4 hours to do.
1. meguiars nxt shampoo
2. dry it
3. meguiars nxt tech wax
4. drive it
doesn't take too long and works a treat
obviously not as perfect a job as some folks fifty-three step processes but if you can't be arsed with that whole shennanigans then i'd recommend the above
inbetween that there's obviously the drying the car, doing the wheels & inside of the car etc but that doesn't take too long either - probably about 2 hours tops.
2. dry it
4. drive it
It didn't deal with the swirls, as the press release indicated it would. Anyone know how to?
I find I always have to polish the car as I just can't get rid of all the watermarks after washing and drying.
My last car (Astra GSI Turbo) was pearlescent blue - I could use the Extra Gloss without polishing every time.
Anyone know the secret?
never could get the hang of the polish too, always comes out a bit greasy. I think you have to put a very very thin layer on. I prefer nxt tech wax for ease, great results, but doesn't imho last as long as carnauba wax and attracts dust.
If there is a way to get the same without polishing heck i wanna know about it!?
Nick, you got it all wrong with the Stage 1. Its not a shampoo, it works very well to remove oxidisation and other crap (inc swirls) to provide an excellent base for polishing and waxing. IMO you missed the most important stage.
The problem with Meguiars is that although the products produce great results they aren't easy to apply and remove - its very tiring. I have got all 3 stages, but I have changed to the following, which is the equivalent of the Meg's 3 stage:
1. Clearkote Vanilla Moose Handglaze
2. Poorboys EX Sealent
3. P21S Carnuba wax
The same results (longer lasting) with half the effort. P21S can be applied in driect sunlight and is a doddle to apply and remove. Takes me <20mins to do the whole car.
3. P21S Carnuba wax
That greasy stuff is old residue:
To avoid it, you need to use the Meg's instant detailer & gay bar. Quickest way of surface prepping the car.
I did the Civic a couple of weeks back, had no problem with the finish. The 1st two coats went on & came off totally cleanly.
I used Collinite wax & the Supersonic Blue looked like flip paint! Not bad for a 5 Y/O car!
3. P21S Carnuba wax
3. P21S Carnuba wax
The best way to use the Deep Crystal Polish is to apply it thin, after letting it haze remove the top layer and do the rest of the car. Now the remaining oils will have formed a new hazed surface. Remove it again and you are done. Think of it as skin on a pudding as it cools down and you get a fresh layer soon after. HTH
Come to the meet on 18 June if you are interested in finding out more.
