Mirror bolt size
Old Feb 1, 2006 | 10:00 AM
Kobe's Avatar
why are you trying to make this more difficult.. I think you will have no chance with one of those t-bar things.. a simple spanner is needed?
if you still don't believe.. then read this..
https://www.s2ki.com/forums/index.php?showtopic=158388
Old Feb 1, 2006 | 10:18 AM
nickrg3's Avatar
interesting write up there. I figured I would shove the t-bar through the hole at the top where the power cable runs through here and as per the above sketch - makes more sense but..
If I can just pull out the speaker and slide my arm up there that looks nice and simple... so long as you dont drop the bloody bolt! Actually you could work both ways if you struggled with the spanner, hand up there to guide and t bar through the hole.
Will take a look on saturday. Wondering if a bathroom plunger might be over the top on the door.....
Old Feb 1, 2006 | 10:25 AM
nickrg3's Avatar
interesting they say 10mm too... Anyway, thanks for the link - very helpful
Old Feb 1, 2006 | 10:34 AM
Kobe's Avatar
the mirror actually is attached with 3 studs.. you need to undo the nuts..
can be ideal to get some help as you will have to hold the mirror somehow as you take the last nut off..
I also could not get my right arm in the gap..
Old Feb 1, 2006 | 11:11 AM
AquilaEagle's Avatar
Administrator
I wouldnt try and suck the dent out or anything nick but interested to see how it goes
Old Feb 1, 2006 | 11:17 AM
nickrg3's Avatar
Im hoping it will just pop out, especially as I can lightly pull on it via the hole behind where the mirror normally covers - should be dead easy! and
Old Feb 1, 2006 | 01:47 PM
simonprelude's Avatar
The thread is 6mm * 1mm, the bolt head / nut may well be 10mm.
Old Feb 4, 2006 | 02:18 AM
Administrator
Let us know how it goes nick
Old Feb 11, 2006 | 04:54 AM
nickrg3's Avatar
OK I bought a 10mm T-Bar as per the pics below.
Now this is a great solid lump - much impressed considering it only cost
drifts2
Jun 27, 2014 08:40 PM
zippity
Mar 8, 2011 01:45 PM
watchdogd
Nov 12, 2009 10:01 AM
nickrg3
Sep 2, 2005 09:12 AM
nickrg3
Jul 5, 2005 12:56 PM
