MPG
Old Jun 3, 2009 | 02:12 AM
  #51
J_D's Avatar
J_D
Sorry I just hate threads like this, theres loads of them on here If you type in "MPG" in the search menu.
Im sure you'll find your answer in there some where, If you'll ecuse me Im off for a sleepy drive zzzzzzzzzzz
Old Jun 3, 2009 | 03:46 AM
  #52
98RON's Avatar
[QUOTE=gaddafi,May 31 2009, 11:59 AM] complete and utter
Old Jun 3, 2009 | 03:54 AM
  #53
s2konroids's Avatar
My advise is dont run on 95Ron unless you cant get 97+Ron , its not going to blow up the engine or anything so it will be 'okay' on 95.
The ECU will just retard the timing hence a little poorer performance, and possibly MPG.
TBH I'm only interested in MPG on long runs on motorways etc which is far and few between now on the S.
FYI failing/dodgy sensors etc can result in poor MPG but then thats obvious.
Old Jun 3, 2009 | 05:07 AM
  #54
afs98mrj's Avatar
well why not just not look at the thread then?
Old Jun 3, 2009 | 05:44 AM
  #55
lower's Avatar
Originally Posted by Hypersonik,Jun 1 2009, 11:53 PM
Speaking of fuel economy, I am sick of getting 20mpg, even when I drive slow.
I have replaced my primary o2 sensor today, even though I had no CEL, in a bid to improve this.
I fail to believe that my right foot is the cause because I seriously think I odn't drive that aggressive anymore.
I had this with my first S. It also wouldn't VTEC smoothly and idling was a bit rough. MPG dropped from 240-250 miles between fill ups (which were around 45L per fill) to 200 miles for the same fill up.
Giving the map sensor a tap, cleaning its connections and resetting the ECU sorted it out.
Something similar then happened to my current car just before the engine was replaced but as the engine was due to be replaced i didn't bother doing anything about it. When i got the car back with the new engine in the problem had gone so i assume it was related to the engine damage or a poor connection that got corrected as part of the engine swap.
Old Jun 3, 2009 | 10:06 AM
  #56
woojah's Avatar
I think people have reported that they get worse MPG on 95 ron.
Therefore it might be a false economy to go for that - ie 98/99 ron might cost 10% more, but it may give c 5-10% better MPG.
I wouldn't worry about fuel economy too much. Have you considered how much insurance will cost you? IMO that's probably the greatest potential "running cost" of the S2000.
Old Jun 3, 2009 | 10:13 AM
  #57
neily.m's Avatar
I get 280 miles from a full tank. The fuel gauge is a bit dippy though as it drops from 2 or 3 bars to 0 very quickly!
Old Jun 3, 2009 | 10:54 AM
  #58
razzele's Avatar
My record low was 86 miles to a tank !
(at Coft)
Old Jun 3, 2009 | 11:01 AM
  #59
jakesalter's Avatar
I have had 325 miles on a tank before.
Old Jun 3, 2009 | 11:02 AM
  #60
Ultra_Nexus's Avatar
I don't thikn I have done the MAP whack/clean so i'll certainly give it a go, cheers rich (and JD who also suggested the MAP).
However, I filled up yesterday and in the interest of good science, I will leave it alone until I use this tank up to see if the o2 sensor alone has had any impact
goblueS2K
May 17, 2018 06:11 AM
mrburtonsir
Aug 3, 2012 12:05 AM
p0staboy
Dec 6, 2009 10:43 AM
Ulrich
May 20, 2003 01:33 PM
