New brake discs
Old Apr 1, 2015 | 03:19 AM
bartonbeau's Avatar
Default New brake discs
Hi, just received new Bremtech brake discs from Brakeparts, the discs are coated in an oil of some sort, obviously to prevent rust. I have a can of Halfords brake cleaner which says it "removes brake dust", will this product be adequate to remove the oil or what do I need to use? The pads have arrived from Si as well, so going to fit at the weekend. Got some Red Rubber grease and copper grease for the job too. I must say the service from Brakeparts was excellent BTW, can even track where the courier is on Google earth. Si excellent service as always.
Old Apr 1, 2015 | 03:32 AM
Gaffa's Avatar
Yes brake cleaner should shift it,
I would not use copper grease though its shite get some Ceratec its quite cheap and much better you can use it on the slider pins and back of the pads
Ian Lillystone's Avatar
Brake cleaner will be fine, just spray on and rub with a cloth
Old Apr 1, 2015 | 10:00 AM
bartonbeau's Avatar
Great thanks guys, i'll get some Ceratec ordered.
Old Mar 7, 2017 | 11:12 PM
Spartaco's Avatar
Hi , thinking of getting Bremtech discs for my S2K , what do you think of them and which ones did you get ? , the drilled / grooved ones ?
Old Mar 8, 2017 | 02:16 AM
richmc's Avatar
Drilled and grooved = cracked and busted, unless you are tracking regularly and therefor replacing them regularly stick to plain discs, perfectly good for road use and the occasional track outing.
S2Kriminal
Feb 12, 2013 01:04 PM
Opie Oils
UK & Ireland Traders Forum
Feb 17, 2012 12:35 AM
gtg749m
Jan 11, 2010 01:06 PM
jah
Dec 16, 2005 06:20 AM
5Gs
Mar 4, 2005 03:01 PM
