New immobiliser unit
Old May 25, 2008 | 01:22 AM
juventino's Avatar
Default New immobiliser unit
Has anyone had a new immobiliser unit replaced in their car?
There's a problem with my immobiliser (no green key shows up on dash and car does not start) - the car is currently with Honda and will be looked at on Tuesday. It was an intermittent problem that got worse at the pub on Friday so RAC called out.
They said that a replacement would cost
Old May 25, 2008 | 01:27 AM
oxhouser's Avatar
get a quote from a car alarm installer for a stand alone CAT 1 imobiliser
I am sure you could get one installed for much less, if its built into the Honda EMS then you could still get change from a cat 1 imobiliser and a spoon EMS
Old May 25, 2008 | 02:51 AM
killasystems's Avatar
its more then likely the main unit under the seat im actualli a alarm installer myself and you can have a new one put in and installed for a mere
Old May 25, 2008 | 03:21 AM
j8mie's Avatar
I had a fault with mine, and they fixed it for
Old May 25, 2008 | 04:12 AM
juventino's Avatar
Thanks - could anyone recommend a place in West Kent? I found a place called Vehicle Technology Systems in Sevenoaks that I'll call. They do the Clifford Cat 1 G5 unit which seems to be real high spec.
Old May 25, 2008 | 04:30 AM
Post
clifford are very good systems untill they give you a problem then its one after the other..i would reccomend that if you are definantly going for a clifford go for somthing not too complicated....
nicky-wah
Apr 15, 2013 09:47 AM
ian220574
Feb 16, 2005 12:39 PM
zero_to60
Jan 7, 2003 02:59 AM
adfrad
Feb 6, 2002 07:56 AM
mrsoften
Jul 24, 2001 11:47 PM
