Not using the car for a long time - brakes
Old May 12, 2008 | 04:26 AM
PJD's Avatar
PJD
Default Not using the car for a long time - brakes
When I haven't used the S for a good few days (or even a couple of days sometimes), release the handbrake, then try and pull off and it feels like the brakes are on, - there's a loud clunk noise and then all is back to normal.
I'm sure this is a common issue, I do remember reading something about not leaving the handbrake on if you're away for a couple of weeks, - what is this all about?
Old May 12, 2008 | 04:37 AM
funster's Avatar
Plenty of discussion about this one even in the last few weeks.
Perfectly normal too, especially in wet/damp weather (or after you've given the car a wash). Handbrake off, leave in gear if not driving for a while - assuming you're not parked on a massive slope!
The pads get 'stuck' to the discs with rust. 'De-sticking' them generates the clunk when you (gently!) pull away.
Old May 12, 2008 | 05:20 AM
PJD's Avatar
PJD
Ah that's what it is, thank-you.
So there's a danger that pads can get siezed if left too long then?
Old May 12, 2008 | 05:47 AM
jakesalter's Avatar
Unlikely to seize fully unless you park your car near to the sea for long periods. A good tip (once the engine is warmed through) is to drive along and do a bit of left foot braking (will take some practice if you havent done it before) to 'wear off' the light surface rust on the discs.
Old May 12, 2008 | 06:06 AM
PJD's Avatar
PJD
Nice one, - thanks for the info there
Old May 12, 2008 | 12:18 PM
wingnutLP's Avatar
TBH I have found that driving and stopping even a couple of times clears any rust and frees up the calipers...
Old May 12, 2008 | 11:01 PM
NNervous_R's Avatar
Washing the car is always followed by an enjoyable 30 minutes or so of driving to "dry the brakes". Also when parking the car in the garage I don't use the handbrake, just first gear.
tonksy
Jul 21, 2013 02:16 AM
Stoatmaster
Apr 27, 2011 07:47 AM
shamoo
Mar 16, 2010 11:12 AM
speedblind
Sep 7, 2006 12:21 PM
dave99
May 6, 2006 02:43 AM
