Numpty a$$ number plate question
Old Sep 23, 2004 | 12:15 PM
Kelk's Avatar
Default Numpty a$$ number plate question
OK guys Dreamer has asked me to change her number plate over on the car. The new number plate is undrilled and I can sort that. My question is how do you take a number plate off a car.
Are they screwed on? Are the srcews hidden beneath the caps or are they not caps and actual plastic type rivet like things?
I did say it was a numpty question.
Old Sep 23, 2004 | 12:19 PM
eSeM's Avatar
My plates are bolted on, some are screwed on and some are stuck on.
Bassoctopus's Avatar
Probably screws under there.
I think the preferred method of fixing is to get some number plate fixing tape from Halfords.
Old Sep 23, 2004 | 12:23 PM
Neil.H's Avatar
My plate is held onto the mount with spongey sticky tape.
san2000's Avatar
Try and gently prise it up Chris. You should be able to see if it's stuck or not with adhesive. If so, just keep pulling.
If screwed on......stop pulling.
Old Sep 23, 2004 | 12:29 PM
MrV's Avatar
MrV
Hammer and bolster should do the job
Old Sep 23, 2004 | 01:27 PM
mikey k's Avatar
:anorakon:
1) If it has a slot or cross in a plastic head protruding from the plate it is probably bolted on with a plastic nut.
2) If it is a dome shape sticking out it is a cap hiding a normal screw.
3) If nothing sticks out from the plate is is taped or clipped in a frame!
:anorakoff:
I guess a couple of pics will probably get your question answered
Old Sep 23, 2004 | 01:47 PM
AquilaEagle's Avatar
Administrator
stick the new one on with Number plate fixer stickers from Hellfords, much cleaner than screws
Old Sep 23, 2004 | 02:27 PM
Kelk's Avatar
Cheers for the help guys - I shall attempt to fix it tomorrow morning and no doubt attatch it upside down
Old Sep 23, 2004 | 02:31 PM
mikey k's Avatar
that will tax the scamera's!
