P0420 fault code. Catalytic system
Old Jan 28, 2023 | 06:38 AM
XAlp's Avatar
Default P0420 fault code. Catalytic system
Hi
I had the yellow engine “environmental” warning light come on, so plugged in an OBD reader I borrowed.
Gave the code P0420. Catalytic system efficiency below threshold (Bank 1).
It had the cat replaced and an after market exhaust fitted previously.
Do you think I’m OK to drive it (seems fine)? Any suggestions to fix?
Old Jan 28, 2023 | 09:45 AM
gtman's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
I got the same warning when I had an aftermarket CAT fitted on my car many years ago. I still drove it for years racking up the mileage and it did not cause a problem so the car will be fine to drive.
I believe it was because of the O2 sensor and I think the recommended solution was to add a spacer to the O2 sensor but I never bothered. I would just reset the warning whenever it needed to be MOT'd. I now have a Berk cat fitted which already has the spacer and the warning light no longer appears.
Old Jan 29, 2023 | 12:16 AM
Nottm_S2's Avatar
This might help
https://www.s2ki.com/forums/s2000-un...1174894/page2/
cosmomiller
Aug 18, 2022 09:36 AM
Nand01
Apr 16, 2012 05:58 AM
Brian Si
Jan 3, 2010 07:31 PM
davygall
Apr 30, 2008 02:26 AM
HiRpmVTEC
Feb 26, 2007 05:25 PM
