Passenger side window stopped working
no, not what your thinking!I stupidly left the window open last night and it pored with rain and now the window won't function, does anybody know if the switch/motor will be ok once it dries out or am I looking at having to source a new one
Everything should be ok when it dries out
It's possible that the fuse has blown as well, by trying to operate the window when the electrics were wet. It should reside in the fuse box beneath the dash, driver's side.
It would be worth checking the ECU area is dry, and putting the aircon on for a few drives to help the cabin dry out.
If the carpet is sopping wet, you an remove some gromits under the carpet to aid draining
This appeared on the S2Ki facebook page - guess you might need it?
https://www.s2ki.com/home/2010/08/19/diy-ho...regulatormotor/
