Passanger window won't go down
Old Mar 10, 2012 | 11:49 AM
Kikodaz's Avatar
Default Passanger window won't go down
Already search this and all I got was some threadas that said to check the switch and that resolved it. First thing I tried was that, wasn't it. Switch fuses with the driver's side window and the drivers side window also worked so it isn't that. I removed the panel and disconnected the switch of the passanger side to see if some how it went down with the driver's side control and that didn't work either.
So I'm all out of ideas to try before buying a new motor. Is it the motor or should I try something else before buying it?
Old Mar 10, 2012 | 11:53 AM
dwight's Avatar
Does it go down when you put the top down?
Old Mar 11, 2012 | 05:05 AM
Kikodaz's Avatar
The top won't go down. It can't go down unless the window is down.
Old Mar 11, 2012 | 10:44 AM
T-Smac's Avatar
Convertible top module. The passenger window is wired through it.
https://www.s2ki.com/...1#entry21042170
One of my posts in there shows how to test the module. You'll need a multimeter.
Old Mar 12, 2012 | 03:06 PM
Kikodaz's Avatar
Thanks! I guess I have to find a multimeter.
elkdaddy
Feb 22, 2018 06:10 PM
plizzat
Aug 10, 2015 03:49 PM
Benn-O
Jul 4, 2010 10:22 AM
darkin.1
Jan 15, 2010 08:26 AM
Ponch
Nov 6, 2009 11:52 AM
