Please assist- which sensor! :(
Old Apr 1, 2013 | 01:09 PM
  #41
RichSouth's Avatar
Thanks pal.....all just so frustrating....
Primary lambda is in the cat right? exhaust leaks around the cat area maybe? As this is the only area that has been messed around with.
The map sensor was replaced like 10k ago so strange if that is duff...
All just a proper headache!
Was thinking of just getting a new lambda as this was what the original code was....
Grrrrr!
Old Apr 1, 2013 | 01:22 PM
  #42
MB's Avatar
MB
Member
Primary lambda is in the manifold, just before the cat.
Any leaks around there, mostly before it, will cause you issues. It may be the wiring down there - which is when you need someone who knows how to use a multimeter / OBD scan tool.
Old Apr 1, 2013 | 01:59 PM
  #43
Daytona-Dave's Avatar
Smoke it and scope it
Old Apr 1, 2013 | 02:01 PM
  #44
MB's Avatar
MB
Member
Yup. Do you have a smoker?
Old Apr 1, 2013 | 02:07 PM
  #45
basic tools these days, you gotta have a smoker and with the code's above I'd smoke it first then do the usual clean outs, clear codes and scope the sensors
Old Apr 1, 2013 | 02:10 PM
  #46
MB's Avatar
MB
Member
I guess you could improvise at home... i've actually seen something similar with cigarette smoke
We use smoke bombs on big turbine air intakes.
This does feel like an air leak problem.
Old Apr 1, 2013 | 02:13 PM
  #47
We use smoke bombs on big turnine air intakes.
Yeah i've seen the guy with the cigar, you need the pressure though most run at 1 1/2 bar so will show up even the smallest leak,,
Old Apr 1, 2013 | 02:31 PM
  #48
RichSouth's Avatar
Really...? Where do you blow smoke...? haha and what with...? Sounds a bit mental...
  #49
RichSouth's Avatar
Scrap the car I'm thinking. Its doing my head in...
Old Apr 1, 2013 | 02:36 PM
  #50
I use a machine, but this guy has different ideas
[media]http://www.youtube.com/watch?v=zMok2y05jNE[/media]
