power loss
power loss
Car was professionally tuned a while back (couple of weeks ago) and when out driving hard the car went all of a sudden from zippy to chug chug chug chug etc - it pops and bangs when on throttle but is fine on partial or cruise. I dont have a wideband so is there anything that I can check before going back to the dyno?
I didn
I didn
Sounds like it's running way to rich on WOT or it's missing?
Are your plugs tight and in good condition?
I may be miles out there but it's something to at least check
Member
I would bet that you have lost a cylinder, Kit Kat (plug nackered / injector wire snapped / injector blocked)
I had exactly the same on my Exige when I had an injector wire loose (my fault!) Car shakes due to the combustion imbalance and becomes very slow and noisy!
Check your wiring and plugs before replacing any bits.
Member
Originally Posted by kitkat,Dec 22 2008, 11:30 AM
thanks MB - thats exactly the kind of info i need to start! BTW does that mean that its running uber rich ?
If you have a cylinder not sparking or injector stuck open then it will just be pumping unburned fuel out the exhaust.
I am no expert on S2000's as I have only just picked mine up but the symptoms do sound like one of the HT leads is starting to break down.
Before a total failure happens the lead can start to fail only at certain frequencies and you end up running on 3 cylinders, ease off the pedal and it runs fine again and ticks over with no issues.
Certainly worth checking it is something relatively easy/cheap to fix like this before exploring other causes.
