Question: about h/lamp height adjustment
Old Nov 4, 2006 | 08:21 AM
Lloyd Six's Avatar
Default Question: about h/lamp height adjustment
Just wondering... S2000's have headlamp aim / height adjustment motors so where is the switch to adjust the aim????
Old Nov 4, 2006 | 08:22 AM
Kobe's Avatar
it's automatic..
though if you have a JDM you need to do it manually.
Old Nov 4, 2006 | 08:25 AM
Lloyd Six's Avatar
Originally Posted by Kobe,Nov 4 2006, 09:22 AM
it's automatic..
though if you have a JDM's you need to do it manually.
cheers mate
I did hear it buzz when I turned them on after having the lamps out.
Automatic does confuse me a little tho, how does it know what is level???
Old Nov 4, 2006 | 08:29 AM
Kobe's Avatar
there is a sensor in the rear subframe.. that somehow detects the angle of the car..
Old Nov 4, 2006 | 08:40 AM
Lloyd Six's Avatar
hmmm... unreal.
I suppose like a load sensor, more weight in rear it will lower beam vice verca.
Clever stuff except for when you fail the MOT on headlamp aim
Old Nov 4, 2006 | 08:51 AM
Kobe's Avatar
I think it picks up an angle between the subframe and the suspension arm.. as the suspension is loaded - it moves relative to the subframe and the angle changes.
Old Nov 4, 2006 | 01:32 PM
AquilaEagle's Avatar
Administrator
They are adjustable, outside of the auto thing - the auto just makes small adjustments for inclines etc..
Old Nov 4, 2006 | 01:52 PM
Kobe's Avatar
inclines?
it only adjusts every 3 minutes
isn't that adjusting screw exactly where the motor is for the auto adjuster.. i.e you can't have both?
Old Nov 5, 2006 | 02:07 AM
Administrator
hmmm I'll have a proper look, because one of my lights is out of line with the other, and it needs adjusting.
Maybe it can be manually done to get the right height and then the auto adjuster makes small adjustments
Old Nov 5, 2006 | 02:19 AM
Kobe's Avatar
I never looked at the UK car..just going from the ESM info.. I had to play with the manual adjusters for my MOT on my JDM when I changed the ride height.
and whilst you are interested in headlights.. if you spot a drivers side for sale anywhere (MY01).. let me know
ramsascooby
Feb 7, 2019 01:26 PM
yorkies2k
Mar 1, 2012 03:15 AM
Reco2k
Feb 9, 2010 03:55 AM
vassosva
Jun 3, 2009 06:23 AM
MuckaLun
Mar 19, 2008 05:43 AM
