Radio on without keys?
Old Apr 23, 2003 | 05:11 AM
Roadkill's Avatar
Default Radio on without keys?
Can it be done. ...
Can I leave Steve Wright wittering on whilst I run into the bakery with my keys? Can I park somewhere and have the radio playing with the door open without the door alarm going off?
Is this too much to ask?
Am I being a muppet?
Old Apr 23, 2003 | 05:29 AM
tnt's Avatar
tnt
Try taping the door switch down
Old Apr 23, 2003 | 05:52 AM
mikepritchard's Avatar
From memory of other stereos, the head unit will be fed 12V by 2 wires. 1 will be a permanent live to keep the radio memory presets/clock etc. The other will be live when you turn the key I.e the radio will be on with the ignition on. You need to identify this wire and make it a permanent live also. Then the radio will play Classic FM for you until you switch the unit off yourself or the battery dies. HTH.
Old Apr 23, 2003 | 07:56 AM
Roadkill's Avatar
Thanks Mike, I'll investigate. a much more favourable response than the post above it!
Old Apr 23, 2003 | 08:08 AM
ninegrand's Avatar
Hi from the other side of the pond.
I found that if you remove the ECU backup fuse it cuts power to the door chime.
Not sure if this is the solution you are looking for but it's what I do when detailing the car so I can listen to the radio without the annoying chime.
Cheers
Old Apr 23, 2003 | 08:39 AM
tnt's Avatar
tnt
But a darn sight easier to do and one that even I understand
Old Apr 23, 2003 | 11:01 AM
Roadkill's Avatar
[QUOTE]Originally posted by ninegrand
[B]Hi from the other side of the pond.
starrman
May 24, 2011 12:43 PM
g352s2k
Jul 15, 2008 07:28 PM
s2kxier
Nov 23, 2006 05:59 AM
STL
Apr 22, 2005 06:34 PM
Destiny2002
Apr 10, 2002 05:55 AM
