Re-greasing the Gear Stick / shifter
I did it last weekend, parts from Honda £18 and I used normal high temp grease. Works fine and all in all took approx 1 hour. Also recently did the clutch fork ball joint sanding and regrease mod, which takes about 1.5 hours and that made a huge difference in clutch pedal feel.
Same grease as I've been using and after 7 years it's still what I use for this.
I've had a quick search for this bronze replacement but can't find anything - any chance you could post a link?? Thanks
I used Starbrite marine trailer bearing grease - it has a dropping point similar to most "normal" greases of about 180C ( NLGI #2 ) - if my knob gets that hot them I'm in a whole lot of other trouble
I'm guessing something like this for the metal collar https://www.rhdjapan.com/car-garage-...r-ap1-ap2.html and there's a short article on it here https://thes2kandtheant.com/tag/s2000-shifter-collar/ that suggests it doesn't make that much of a difference (plus has the relevant Honda P/N for the other bits)
For the clutch slave "nipple" just grind it off with a dremel, then mount it in a drill and use course then fine valve grinding paste, I did mine this way and it ended up with a mirror finish without much effort.
-Brian.
Stevo071077 (10-30-2017)
Just did this today to my 08 with 51k miles. Shifts feel so much better now and it only took about 45 minutes. I'm pretty rubbish with working on cars but this was so easy!
