Rear camber arms
Old Apr 29, 2012 | 05:13 AM
allard3's Avatar
Default Rear camber arms
I'm after a pair for camber arms don't really want to import a set just wondering what others are available. I've come across the Megan but can't really find any others.
http://www.amazon.com/00-09-Honda-S2.../dp/B0053N4CH6
Old Apr 29, 2012 | 05:17 AM
lovegroova's Avatar
See the traders section https://www.s2ki.com/s2000/forum/101-uk-traders-forum/ I expect Dixon Motorsports sell them
Old Apr 29, 2012 | 05:23 AM
Dixon Motorsports's Avatar
We do sell but you don't need them, stock arms with lowered car can go up to -3.30 degree at the back anyway. How much more camber to you need?
Old Apr 29, 2012 | 12:33 PM
allard3's Avatar
3 degrees is quite abit only way I'm going to tell if i need them or not is when I fit the wheels and get the car to the height I require. (which will be a week or 2)
I will pm you about prices and shipping time shorty thanks for the info.
Old Apr 29, 2012 | 01:39 PM
WinFreak's Avatar
What wheels are you getting, if they need more than 3.5 degrees camber?
Old Apr 29, 2012 | 01:55 PM
MB's Avatar
MB
Member
Yep if you are trying to tuck the wrong offset wheels under the arches by using excessive camber, that's a real bodge!
I have -3.3 and it's way too much.
Old Apr 30, 2012 | 10:32 AM
Adriank's Avatar
I have an issue the other way, Dixon can camber arms allow you to run less camber?
My car is low, has had all the bushs replaced and free'd off but the rear camber can't be adjusted below 3deg on the shims...
Old May 1, 2012 | 11:08 AM
Yes you can bring the camber back to 0 if you want with camber kit.
Old May 1, 2012 | 03:02 PM
razzele's Avatar
I bought Megan top arms to reduce camber. Also a couple balljoints were getting quite tired so I thought it may kill two problems with one cheque.
Ian Fountain
Apr 26, 2019 06:32 AM
balkolite
Jun 12, 2017 12:59 PM
mrbond413
May 18, 2014 09:57 AM
jst2878
Mar 7, 2013 12:48 PM
J_STATUS
Jul 30, 2008 04:22 PM
