Removing the air pump
#22
The reason I have removed mine is to tidy up the engine bay a bit.
#24
If you could mate please, I think I may have figured it out but my relay may have failed.
Does anyone have one for sale? - its the cylinder denso thing.
Cheers
Cheers
#25
Originally Posted by s2konroids' timestamp='1325526453' post='21278992
Wish I never started this lol, still on with it.
Looks like my pump wasn't broke but will update thread if I have the time.
#26
I am not quite sure what you are saying,I had a vacuum pipe to the secondary air pump which went along my fuel rail but I think that was the only one. I had to put a T piece in it to run my dump valve and boost gauge. I don't remember any other small bore vacuum pipes,but I could be wrong.
#27
Glen,
There are 2 vaccum lines, at the end one goes to the EGR valve the other to the rear of the intake manifold. However at the other end you have a pipe that goes to the air control valve (which has an electrical connector) and from there goes into the vacuum tank back out and into the air control control valve.
I'm wondering basically what you with the air control valve, since theoretically you can remove the vacuum tank and all pipes but that leaves the air control valve basically unconnected vacuum wise but not electric plug wise. I plan to run a vacuum line from the port at the back of the intake manifold straight to the Divertor valve on my supercharger.
#28
If you get the chance look at the fitting instructions on the Tts/rotrex, website,that told me what to do with various bits,failing that I will have a look at the weekend and let you know what I did.
#29
#30
Will do thanks Glen.
Think i will leave all connected, do a run in the car and see if i get a CEL then slowly begin to remove things. I'm really hoping the resistor trick will work and its my relay that's faulty. I reckon with everything, vac tank, brackets the lot removed its around 5KG (will help negate most of the weight on the front end, as already have lightweight manifold, no heatshield etc)
Simon, this is the item for future reference, unfortunately i have just bought one - i reckon a normal relay would do now due to the load but couldnt be bothered pissing about!.
