Removing scuff from end of exhaust tip
Old 12-17-2011, 12:12 AM
zzkamikazezz's Avatar
I went for the go tuning greddy spectrum elite dual. Ive got a header and hfc to go on so thought tje q300 would be too loud especially for track days.
It cost me an arm and a bloody leg, 200 postage and same again in import charges but picked it up as a black friday special with $200 dollars off. It had better last longer than the car at that cost!
Old 12-17-2011, 12:17 AM
Harpsi's Avatar
Originally Posted by Chris Harris
Halfords do an assorted pack of wet and dry from 600 - 2000 grit. work your way trouugh the grades and finish with some autosol. Job Done.
This is very good advice, I use this stuff daily in my work but I would add, use it DRY for this job. 400 will take the scuff off and I really do not think you would need finer than 1000 and then polish. The really fine stuff is for really fine body finish work and should be used wet. Good luck.
Old 12-17-2011, 02:15 AM
WinFreak's Avatar
I think you should just put it on the car
AusS2000
08-27-2001 04:10 AM
Quick Reply: Removing scuff from end of exhaust tip
