Replacement dampers - recommendations
Originally Posted by jeremylparker,Jul 13 2008, 12:49 PM
What settings are you looking for on the geo??
jeremylparker Posted on Jul 13 2008, 01:49 PM
Seems ok, except for the handling issue
Are you still on 16" (OEM) wheels?
IMO! the 225/245 combination reduced the stagger a lot.
The 205 S-02 is (IMO
) really narrow compared to other tires so a 225 will be a lot wider, more then the 20mm difference in width suggests.
Anyway... I guess you found out the hard way the S-02's on OEM 16" wheels work really well on the S2000.
I've got 225/50s on the front and 245/45s on the rear - seems ok
) really narrow compared to other tires so a 225 will be a lot wider, more then the 20mm difference in width suggests.Anyway... I guess you found out the hard way the S-02's on OEM 16" wheels work really well on the S2000.
Is it just me or am I mis-reading this thread somewhere?
You've replaced the specific (and they DO have a wider-than-usual, squarer tread on a 225 carcass!) S-02 with a notoriously soggy-sidewalled Toyo and you wonder why the car is less stable on the limit and you suspect it may be dampers?
Either I've missed the bit where it WAS fine on the Toyos, or that's female logic!
Had the geo checked today.
Apart from a little too much toe on the rear - from a recent bump - the alignment was ok. Now adjusted to 'optimum' plus with 1.2 negative front and 2.1 negative rear.
So - it must be the tyres...hence ordered some RE050As.
Cheers
Cheers
robert112
Feb 25, 2007 04:13 PM
