Roof leaks when opening
Old 10-24-2011, 01:41 AM
  #91
s2k_Nut's Avatar
I have exactly those tiny little tear's in my roof, I have applied a clear coloured flexible glue for now I will wait and see if that fixes it !
Old 10-24-2011, 02:05 AM
  #92
j8mie's Avatar
I have the same cracks on my roof as well, and it still leaks despite all the other things I've tried.
Does anyone know where you can pick up Liquid Nails Clear Small Projects Silicone Adhesive in the UK? What have you used Paul?
Old 10-24-2011, 02:14 AM
  #93
s2k_Nut's Avatar
It's called Flash Bonder 'Special-Glue I used this glue to 'stick' a patch to my roof and after several months it's still holding firm no lifts whatsoever, so I just put a pinhead full of this glue down the tiny little cracks, I don't know yet whether it has worked Jamie ... however it is a 'flexible' glue and seems water proof .. so we'll see ...
Old 11-04-2011, 05:07 AM
  #94
Dracoro's Avatar
I have taken the roof apart trying to get to the bottom of this! aahh. Everything I can see is sealed, no way for water to get in etc.
I "think" that water is soaking through the roof, by the edges where the stitching is. Over time, the roof must harden and the stitch holes get more porous (or bigger) and water soaks through these. Maybe moreso where there are cracks (as a result of the roof material hardening etc.).
Anyone any products that I should use to seal all the stitching? Some invisible glue/sealant of some sort that I can run through the length of the stitching.
Old 11-24-2011, 12:53 PM
  #95
j8mie's Avatar
Smokingj & s2k_nut - How have you guys been getting on since you applied your sealant to your roofs?
Old 11-24-2011, 12:57 PM
  #96
s2konroids's Avatar
All i can say is
Old 01-25-2012, 01:19 PM
  #97
hondafreak1983's Avatar
anyone news of this problem?
Old 07-12-2012, 02:06 AM
  #98
Dracoro's Avatar
Appears to be fixed for me after solution I did in post 98 HERE:
Old 06-29-2016, 01:23 PM
  #99
UK Paul's Avatar
Park mine in a garage....
Old 07-04-2016, 01:29 PM
  #100
edi57's Avatar
I had the common issue of water collecting in the rails, then dripping/pouring off when I go to drive away.
I couldn't figure out how water could collect there with my car just parked. I came to the conclusion that it could only have been working its way though the canvas. Therefore, I treated with Autoglym fabric roof product and the car has been bone dry inside ever since. Even through these mega heavy storms that we've been having over recently weeks.
GhostWKD
02-04-2014 07:50 AM
Toms1989
01-04-2014 02:46 PM
rallye666
07-25-2013 07:18 AM
redskel
08-26-2010 09:54 AM
s2konroids
11-19-2007 10:03 AM
Quick Reply: Roof leaks when opening
