UK & Ireland S2000 CommunityDiscussions related to the S2000, its ownership and enthusiasm for it in the UK and Ireland. Including FAQs, and technical questions.
Just as a belt and braces might be worth checking the spark plug underneath the original failed coil pack. Reason I've some spares is I lost a coil pack on the way home from XM.
Did the trouble shooting you've been doing (i.e. diconnected coil pack to ID the cylinder then swap it to check the problem moves with it). Even though everything moved with the coil pack I noticed a lot of dirt on the original coil pack making me double check the plugs and I found this.
The coil was trying to make up for the damage and I think it just burnt itself out
