Con Rod Bearings
Old 08-11-2018, 08:11 AM
Hargreaves's Avatar
Default Con Rod Bearings
I have the rod journal code of
BBCB
and big end bore code is
3232
I have thus come to the conclusion that the bearing colours I need are as follows;
Green, yellow, brown, yellow
can anyone confirm that I’m correct with the colours I have selected?
thanks!
Old 08-11-2018, 02:12 PM
Hargreaves's Avatar
And can I reuse the con rod bolts or do they need replacing?
Old 08-11-2018, 03:14 PM
noodels's Avatar
if within spec re-use con rod bolts,its in the book oem spec ie,check for stretch ect..
your codes looks fine & regarding clearance ,check with plastigauge & re--check .its not a new build.
Old 08-12-2018, 04:53 AM
Hargreaves's Avatar
Always nice just to have someone reassure you. I have plasti-guage and will check the bolts against the specs in the manual. thanks for that!
ppy1111
05-13-2016 09:33 AM
JesusGLS
11-12-2010 08:49 AM
Moddiction
11-26-2009 04:09 PM
Quick Reply: Con Rod Bearings
