Finally! Potential new S2000 owner.. questions
Old 05-10-2018, 06:03 AM
tommys2k?'s Avatar
Default Finally! Potential new S2000 owner.. questions
Hi all,
I've been looking on and off getting an S2K for a couple of years now. I've just blown up my daily driver and finally found one that looks reasonable with a couple of modifications (selling via a mutual friend) and I can insure the thing for under 4 figures now.
The s2000 is a 2001 car, but looks to have been very well looked after.
FSH, 94k, valve clearances done, discs and pads, good coilovers, AD08 tyres, all in all pretty nice.
I'm viewing the car asap, so will look out for rust and several other bits in the thread on here. Am told an alignment has also been done.
RE: Timing chains. Are these lifetime or would you do it as a precaution anyway?
Suppose the only other consumable is the clutch.
Any other top tips for what to look for would be appreciated. I would have rather had a facelift 04+ car, but I'm desperate and still love the look of it.
Cheers guys,
T
Old 05-10-2018, 07:48 AM
andy2000's Avatar
take a look in the boot under the tool tray and inspect from below. make sure it hasn't rusted out (water pooling in the boot due to blocked drains is a common issue)
Also check out the FAQs for some other pointers.
good luck with finding one that suits. you won't regret it
tommys2k? (05-10-2018)
Old 05-10-2018, 07:51 AM
lower's Avatar
Timing chains should not need changing, but read the FAQ about the timing chain tensioner (TCT)
Old 05-10-2018, 02:25 PM
tommys2k?'s Avatar
Thankyou chaps!
I will do just that lower.
Are the TCT's an expensive job? Or DIY mechanic-able?
I'm excited to say the least...
Cheers all.
T
Old 05-10-2018, 10:32 PM
Fellblade's Avatar
I've started mechanic-ing for the first time on my S2000. TCT swap over was ridiculously easy, DIY.
pin64
08-02-2015 06:36 PM
krausean
03-12-2014 02:42 AM
951toS2k
02-06-2014 02:24 AM
Allik
09-12-2011 07:56 PM
kuraz
09-07-2004 11:33 PM
Quick Reply: Finally! Potential new S2000 owner.. questions
