S keeps trying to stall
When i come to a hault in the S, from time to time the revs die down to only a few hundred and then it pics back up again, as yet the car hasn't stalled.
The car is performing well and does not sound fcuked so im not to worried, but none the less curious. I have had a similar problem on previous cars which turned out to be a minor electrical fault so I'm thinking along the same lines here. Has any else got any ideas what this could be?
I'm sure its only coincidence but this has started since I fitted my Invidia exhaust system.
I get this from time to time ,have taken it to honda and so far Ive had the ECU reset 4 times and it makes no difference at all
Dont know if it is a coincidence but stopped useing my local BP station and havent had the problem for the last 6 weeks
Originally Posted by urchin,May 22 2005, 08:01 AM
just an idea, but could it be that the ECU hasn't adjusted properly to your new exhaust?... have you tried resetting it?...
Originally Posted by AquilaEagle,May 22 2005, 08:12 AM
too much oil in it?
Mine seems worst when starting a hot car in hot weather, but not aboslutely sure about that.
I try to ignore it!
Cheers
Jeremy
