S2000 Remap/ Vtec Controller
In fact, in my opinion, getting an OEM car mapped will give you the best BHP/£ return this side of FI.
Obviosuly you'd get an even better return if you improve the breathing first.
Sorry, I meant in terms of needing to get someone to map it properly for me once I get it?
Sounds like it'll be beneficial with my K&N, decat and buddyclub so it'd be nice to have a fe extra HP
That really depends on how much someone wants to charge, some tuners charge as little as £45-50 an hour others £60-70 an hour from what i know of.
IMO its more expensive down south as compared to the far superior region known as 'up narf'
If your not wanting to spend loads but still want a good tune a GEMU is a far better device than a VAFC2, but the VAFC2 aint bad. VAFC2 is map based tuning, the GEMU direct control of the injectors. And a standalone is a better device than a GEMU
This question should be posted in the main S2000 forum rather than the "UK Car Talk non-S2000" mate.
https://www.s2ki.com/s2000/forum/25-uk-s2000-community/
AFAIK remapping an S2000 is pretty much pointless same as any N/A car as only very small gains will be seen if any (I may be wrong and stand ready to be corrected but I'm pretty sure I'm right).
Not sure about a vtec controller.
Cost a lot though.
VTEC controller is fairly pointless in its own. You will have to spend a fair bit on the 'right' breathing mods and select a decent method of altering your fuelling and ignition to get noticeable power.
It's far better device, faster hardware etc. The blue uses a shirty way of changing injector duty cycle using map sensor and direct control, ultimate does it the proper way. It's limited to 650cc Iirc and I don't think ignition timing is as good.
