Should I switch oils?
Old Apr 23, 2004 | 03:04 AM
dws2000's Avatar
Default Should I switch oils?
Going to have a mid service oil and filter change, bit of tlc for the engine.
I use Mobil 1 0W/40 (it's almost impossible to find 10W/40 from them), thinking of moving to the Shell fully synth.
Should I, what do you reckon?????? Will it really make a difference?
Old Apr 23, 2004 | 03:15 AM
AquilaEagle's Avatar
Administrator
not much difference. Ive used Mobil 1 Shell Helix ultra, but now i use Redline 10w30 from fluke motorsport.
Old Apr 23, 2004 | 03:19 AM
JamieS2K's Avatar
[QUOTE]Originally posted by AquilaEagle
Old Apr 23, 2004 | 03:42 AM
Administrator
When i say not much difference, i mean no significant difference to the untrained.
There are some very technical detailed threads about oil, and i have some info too about effects of different oils on the engine, but its soooo complicated, i wouldnt start to try and understand it
Old Apr 23, 2004 | 04:04 AM
Kobe's Avatar
[QUOTE]Originally posted by Jamies2k
Old Apr 23, 2004 | 04:47 AM
mikdys's Avatar
http://forums.s2ki.com/forums/showthread.p...threadid=169852
Take a look at the above thread - it shows that Mobil 1 is pretty good stuff and probably has the edge on other similar oils.
However, that looks like a whole bunch of fine detail and I'll bet you'll never notice any difference between Mobil 1 and Shell Helix Ultra as an owner/driver.
One thing I wonder (if anyone ever did a scientific test on this) is there any theoretical benefit to using the same brand of oil and fuel (they must interact to some extent in the combustion chambers?) I guess most S2000 owners are going to be using Optimax fuel so maybe Shell oil should be a natural choice. Anyway, I can't see it would do much harm to change over.
Old Apr 23, 2004 | 05:19 AM
Bigtone's Avatar
I use Texaco Havoline Energy 5W-30.
Stays clean, no odour, not desperately expensive.
Was recommended by John Cooper Garages who supplied and serviced my car from new.
RoBD305
Jun 21, 2003 11:52 AM
SoCaLChink
Jun 17, 2002 07:05 PM
LIL RAJA
May 29, 2002 08:42 PM
SenSpeed
May 15, 2001 05:04 PM
NA-1
Feb 11, 2001 08:44 PM
