SPOON ECU
Old Feb 12, 2006 | 01:28 PM
mugen888's Avatar
Default SPOON ECU
Just bought a spoon ecu off ebay
just want to know if there's anything i need to do before installing the thing
i read a few threads where it will disable the immobiliser....
that's not good i take it is there anyway round this ?
spoon europe are selling ECU's which will work with immobilisers
Old Feb 12, 2006 | 01:32 PM
Lurking Lawyer's Avatar
Best of luck. At least two members here running Spoon ECUs have seen their engines go pop.....
Old Feb 12, 2006 | 01:35 PM
nickrg3's Avatar
yeah and warn your passenger to wear a helmet
Old Feb 12, 2006 | 10:55 PM
eSeM's Avatar
The OEM Honda immobiliser is built into the ecu. If you change ecu's you need to get your keys reprogrammed.
I would be surprised if the Spoon ecu did have an imobiliser. One way to find out is to plug it in and start the car up.
(How much did you get the ecu for?)
Old Feb 12, 2006 | 11:37 PM
mugen888's Avatar
does anyone know if the immobiliser is a removable erpom on the original ecu if so maybe it can be transfered to the new ecu
Old Feb 12, 2006 | 11:54 PM
Cardiff's Avatar
I was the other guy biddding!!! I did not want to pay more than
Old Feb 13, 2006 | 12:47 AM
Lou S2K's Avatar
You will need to ground the fuel pump
Old Feb 13, 2006 | 12:50 AM
Cardiff's Avatar
Which members blew their engines with the spoon ECU?
Old Feb 13, 2006 | 12:51 AM
Turtle's Avatar
In neither of which case was there anything to suggest that the ECU contributed to the failures in anyway whatsoever. The Spoon ECU has been run safely on a number of UK cars.
mugen888 - no. The map's are on the processor, not an eeprom.
-Brian.
Old Feb 13, 2006 | 01:03 AM
Lickermat's Avatar
There are a couple of wiring changes you will need to make , mainly for the fuel pump. Id speak to Ant at Spoon b4 u do anything
