Squeaky suspension
Old 09-24-2016, 12:15 PM
Fatbloke's Avatar
Default Squeaky suspension
Anyone had problems with squeaky KW V3's before (or any coilovers for that matter), and if so, how did you stop it?
I can't be certain, but it sounds like the noise is coming from the top mount area, behind the boot trim. It sounds like a squeaky bed spring when I go over a biggish bump.
I've given them a squirt of lube but I haven't had chance yet to see if it's made any difference.
Just wondered if anyone has come across it before?.......
Cheers, FB
Old 09-24-2016, 03:04 PM
CTML's Avatar
Have you had new bushes put in recently aswell? Because the bushes will squeak until they soften up with time.
Old 09-24-2016, 10:31 PM
Fatbloke's Avatar
No new bushes but the same thing could apply to the rubber parts of the top mount.
They've been on the car for six months now though......
Old 09-24-2016, 11:29 PM
noodels's Avatar
Assembled my coilovers with lots of white grease before install
Old 09-25-2016, 06:52 AM
Fatbloke's Avatar
The spray grease seems to have done the trick.
Old 09-26-2016, 07:03 AM
saero's Avatar
Can you tell me where did you apply it? Did you put the grease between the spring and top mount or the top mount and chassi?
What product did you use?
Old 09-26-2016, 01:30 PM
Fatbloke's Avatar
Originally Posted by saero
Can you tell me where did you apply it? Did you put the grease between the spring and top mount or the top mount and chassi? What product did you use? <img src=/emot-tip-wink.gif' class='bbc_emoticon' alt='' />' />
I sprayed the top of the struts, where they attach behind the boot trim.
I used GT85 first so that it would penetrate, then clear PTFE spray grease.
rikhemi
03-13-2012 10:40 AM
iNetForce
03-18-2007 06:11 PM
rich337
10-04-2005 11:56 AM
dctrpark
01-21-2005 04:18 AM
dctrpark
05-24-2004 07:22 AM
Quick Reply: Squeaky suspension
