Steering wheels
Old Jul 7, 2013 | 06:09 AM
GreenmanS2000's Avatar
Default Steering wheels
Quick question - did the later models have a thicker rimmed steering wheel?
Old Jul 7, 2013 | 06:24 AM
Bandit_287's Avatar
No but get in touch with Robin on here, he'll re-trim you one to any thickness/colour combo you want. His work is top notch! It's on an exchange basis so you won't be without a wheel.
Old Jul 7, 2013 | 07:54 AM
The Loon's Avatar
The rims were the same. Earlier wheels have perforated leather. The later versions only had non perforated leather. As suggested above contact Robin as he does an excellent job of retrimming wheels in any combo you require
Old Jul 7, 2013 | 08:15 AM
You spotted my plan...
Old Jul 7, 2013 | 08:16 AM
It's an easy DIY home swap to disable the airbag bag?
Old Jul 7, 2013 | 08:45 AM
Bandit_287's Avatar
Are you asking or telling?
Old Jul 7, 2013 | 08:48 AM
Bandit_287's Avatar
I guess you were asking and yes it is very easy.I was a bit hesistant to remove my air bag but it's very simple as long as you disconnect the battery for 30 mins or so before you remove it.
Pull off the two plastic tabs either side of the wheel
Remove the two torx style bolts either side holding the airbag on
Disconnect the airbag and horn
Remove wheel, 14mm nut.
Old Jul 7, 2013 | 11:39 AM
Ergh - it was a question . Bad typing ...
weksos
185
Mar 17, 2014 06:14 PM
razzele
Jan 19, 2011 09:56 AM
dyhppy
Nov 16, 2010 04:48 PM
hammerhead300
Apr 24, 2009 09:56 AM
Rick Hesel
Jul 21, 2001 09:31 AM
