Stereo Issues
Old Dec 12, 2007 | 03:33 AM
Paper Lawyer's Avatar
Originally Posted by MC_BLADE,Dec 12 2007, 09:38 AM
I'd suggest if you decide to take your head unit out, or take the door card out. Do both at the same time and test for continuity between the wiring loom and the spade connectors at the other end. Thus you will be able to wiggle the wiring at both ends one at a time and find where the fault lies, also check for breakdown from the positive to the negative of the run.
I've tried this but my problem is so intermittent that it is difficult to identify the problem. I swopped channels on my amp and still the same door speaker was affected, so I know it is the wiring to the crossover (unlikely), the crossover itself (replaced all capacitors recently), the wiring to the tweeter (possible - I've taped up the little amount of exposed metal on the spade connectors) or the tweeter itself.
EDIT: and I also tried swopping tweeters and the problem remained with the same door panel - so wiring/crossover the only remaining potentially faulty elements.
Old Dec 12, 2007 | 04:46 AM
MC_BLADE's Avatar
Is it possible to swap the crossover, or swap the channel it uses on the crossover - Right to Left.
Then you will know for sure whether its the run or the cross over.
NB dont check a circuit with a crossover connected, it should be open circuit across terminals on a typical crossover.
Old Dec 12, 2007 | 06:37 AM
Shipley's Avatar
I had this, pop the door card off and have a look at the speaker. (Mine's a JDM BTW).
The speaker terminal had rusted causing the fault so I upgraded the speakers.
Kenny_Stang
Jul 31, 2017 09:46 AM
europa
Dec 20, 2008 11:24 AM
s2kkyo
Dec 9, 2007 12:36 PM
hornyhonda
Oct 4, 2004 12:01 PM
offroadr35
Aug 9, 2003 11:51 PM
