Strange vibration?
Old Sep 23, 2011 | 09:12 AM
o O MARK O o's Avatar
Default Strange vibration?
Hello All,
The S seems to have developed a strange vibration around 3-4k rpm, it will then smooth out then when vtec kicks in it feels hesitant and is not as smooth as was a few weeks ago,
the vibration feels the same as a wheel that is not balanced correctly,(shakes the cabin)but then smooths out????
and in vtec, the best way I can describe it is, it feels like fuel starvation????? (but no vibration)
The car has a de-cat, after market exhaust, and a CAI kit, I also fitted new tyres all round (falkens) and changed the oil and filter (castrol edge 5/40)
all this work was carried out a few weeks before JAE and the london tunnel run and the care drove like a dream for the whole 540 miles, so I am struggling to tie the symptoms with any of the above work,
I have checked the oil level, all the wheel nuts and the car nothing is jumping out at me,
PS its a MY01, with 103000 miles,
Any ideas would be a big help, Thank you Mark
Old Sep 23, 2011 | 09:22 AM
Zudzilla's Avatar
hi mark,
Does it vibrate the same when stationary or only when moving?
martin
Old Sep 23, 2011 | 09:29 AM
Hi Zud,
Only happens when the car is diving under load, and in any gear,
Had a look at some other posts and wondering if it might be an engine / gear box / diff mount
Or mybe the prop shaft???
Old Sep 23, 2011 | 09:53 AM
loftust's Avatar
It could be the driveshafts...these symptoms sound similar to what andy2000 experienced ~ 15 months ago...he also had a similar mileage to yours.
Fitting driveshaft spacers would rectify the issue, or swapping the buckets over.
Have a search for driveshafts Mark and see if your symptoms tie up with anyone else's.
Old Sep 23, 2011 | 10:17 AM
Thanks Matt,
I have also fitted the HKS lowering springs last week that I picked up at JAE, so was thinking about some spacers anyway, so I will look into that,
I did not mention the springs in the first post as the car had the problem before they were fitted,
Old Sep 23, 2011 | 10:22 AM
loftust's Avatar
They wear without the ride height being altered...just as Andy's did
Old Sep 23, 2011 | 10:30 AM
s2konroids's Avatar
How much does hks springs lower by?
Old Sep 23, 2011 | 11:04 AM
Bought them second hand, according to the seller 25mm front and 30mm rear
before......
after......
Old Sep 24, 2011 | 02:14 AM
Fontal's Avatar
Yup I'd say its driveshaft spacers needed mine did the same after I fitted the springs (still haven't got any spacers)
bjt1ngle
Sep 29, 2011 03:55 PM
s2k_Nut
Apr 29, 2011 03:18 PM
Random1
Aug 6, 2007 08:56 PM
silverap1bullet
Oct 5, 2006 08:54 PM
Money2536
Aug 26, 2003 10:03 PM
