strike 3 for the diff
Old Mar 12, 2010 | 09:53 AM
veehexx's Avatar
Default strike 3 for the diff
been having issues with the diff over the last year or 2- i've been letting it progress.
first off it starts feeling tight on full lock scenarios. - might of been down to me being unfamiliar with LSDs..
then it started vibrating on full acceleration. i thought this may of been down to failing shocks. while used replacements did help, a few months later the vibration returns.
and finally it clicks/clunks now and again as i move forward/back slowly. maybe hub nuts, but no - they are tight. been having lots more clunks today hence this post.
so time to look for some used diffs... i think it's had it's life.
Old Mar 12, 2010 | 10:06 AM
NineBolts's Avatar
After the winter we've just had there ought to be plenty
Old Mar 12, 2010 | 11:46 AM
LTB's Avatar
LTB
You positive that it is the diff ?
It may be the half shafts or the CV joints.
Just a thought.
Old Mar 12, 2010 | 12:50 PM
mattyc's Avatar
I would say it's the inboard cv joints too. Take them off clean out all grease and refit on opposite sides and repack with new grease. Simples! Cheap fix I did mine and now they are sorted only cost a few quid for new grease too.
Matty
Old Mar 12, 2010 | 02:40 PM
m1bjr's Avatar
Matty
And swap the buckets over too, and grease them well.
Old Mar 13, 2010 | 12:05 AM
veehexx's Avatar
humm - i never thought about the CV joints.
thanks for the sugestions. might be worth a swap over to see what happens.
looks like a straight forward job - undo hub nut, undo diff flange bolts and out it comes!
only parts needed is extra grease and new crimp clips for the CV boots.... and some rubber gloves 'cause that grease is messy!
Old Mar 13, 2010 | 12:10 AM
tej's Avatar
tej
My diff feels quite tight from cold on full lock, I also get a click/clunk when breaking hard from under the car that might be the diff.. hope its not on its way out too
Old Mar 13, 2010 | 12:23 AM
veehexx's Avatar
well I'll probably know by monday if the drive shaft swap fixes my issues.
gonna pop out later to get some grease & clips, then do the work tomorrow.
it looks like it could rain, but it needs doing. im either at work, or away for the entire weekend for the next 2 weeks and will be clocking up some miles; don't want it to be going pop!
1SlowSi
Nov 11, 2014 01:35 PM
ryanswhites2k
77
Jul 7, 2009 10:55 PM
veehexx
Apr 26, 2009 10:36 PM
Tjs S2k
Apr 29, 2008 01:46 PM
Talstaff
May 6, 2007 12:34 AM
