Subtle switch location
the steering wheel on the S has blanking plates for cruise control. maybe the switch can go there? it might even have wiring present through the steering assembly.
surely the best place for a nitrous switch is somewhere where you have both hands on the wheel so your in full control...
WOT is used
Originally Posted by David.mt' timestamp='1328093745' post='21372472
Surely the switch just engages and primes the system and you also have a throttle switch such that the nitrous only flows at WOT?
WOT is used
As stated above, the switch does prime the system ready for use, and nitrous flows at WOT via a TPS switch.
However, if you are already at WOT then you can flick the switch to engage the nitrous. For that reason it needs to be easy to access.
Thanks for the comments regarding the sterring wheel, mine has no buttons on though, but maybe this is something I can look into.
Thanks Ross, I've read that thread already, that's where I got the idea for making a switch panel from :-)
I think this is the route i'll go down
