Technical FAQ v2.1
Old Sep 8, 2007 | 07:07 AM
  #21
AquilaEagle's Avatar
Administrator
https://www.s2ki.com/forums/index.php?showtopic=478757
Old Jan 20, 2008 | 05:20 AM
  #22
Administrator
Home made hardtop stand
https://www.s2ki.com/forums/index.ph...pic=53467&st=0
Old Feb 11, 2008 | 01:30 PM
  #23
chilled's Avatar
I had to get a new battery today. It's worth noting that the Halfords battery in the faq has two different versions, the both seem identical, but one of them has terminals that are too small.
Old Mar 30, 2008 | 03:41 AM
  #24
RISLAR's Avatar
Post
Here is the programming sheet for the 3 button fob, you can use this to programme a replacement fob.
Old Mar 30, 2008 | 03:42 AM
  #25
RISLAR's Avatar
Here is a spark plug guide:
Old Jun 24, 2008 | 03:25 AM
  #26
Bonesy's Avatar
not sure whether i can add comments here, but
- Passenger Side: Bosch 20" around
Old Jun 29, 2008 | 02:31 PM
  #27
Bouchehog's Avatar
You don't have a section for "leaking roof seals" or "motorway wind-noise" from the hood, both of which would be (have been!) very useful.
I had a problem with wind-noise at high speeds and a leaky hood which was due to wear on the hood striker plates meaning that the seal wasn't tight enough. You link to a thread on replacing the striker plates under "Rattling Roof Catches" but it would help if there were separate sections for those problems - it's a bit of a leap of imagination to go to rattling roof catches to resolve the problem!
Old Jul 8, 2008 | 11:24 AM
  #28
Administrator
Releasing bonnet with broken cable, or lever
https://www.s2ki.com/forums/index.php?showtopic=611460
  #29
Administrator
Removing radio door
https://www.s2ki.com/forums/index.php?showtopic=611364
Old Jul 11, 2008 | 10:12 AM
  #30
Administrator
Boot release faliure
https://www.s2ki.com/forums/index.php?showtopic=612610
