Timed 0-60's?
Timed 0-60's?
Just seeing how fast you guys and gals can get out of the S. i am trying to get the technique together at the moment! tips? oh and its totally standard by the way. and brand new
Originally Posted by Survey S2000,Apr 24 2007, 03:00 PM
how much rpm b4 the clutch came up?
when she started sliding sideways and hitting the limiter, I changed up a gear.
Be careful, take off can be a funny business I tried side stepping the clutch with about 4k dialled in and got the aroma of cooking clutch as I crawlled away from the lights (it was on a slight uphill in the dry).
I've not tried it since it got dry and my re-map.
0-60 isn't what this car does well or what it's about.
0-60 is left for the 4x4 boys in their skylines, scoobies and evos.
To dump the clutch at revs you need to do the following.
get the car into the vtec rev range
lift the clutch gently to the biting point
side step the clutch
the wheels will break free and you'll not drop out of the powerband.
dumping at 4k doesn't nothing really, as you are not up where the power is.
dead right bibbsie re 4x4 and 60
60-160 in mine ws I guess about 15 seconds?
not too sure on the exact figure and wasn't counting
just trying hard to make good changes - I was leaving a TVR by a few lengths at the time
