toluene
Old 03-13-2011, 03:17 AM
Juicy Steve's Avatar
Default toluene
Any one on here actually use it as an octane booster? Having a JDM I've just been reading about it here: http://www.vonkdevelopment.com/PDF/Octanbooster.pdf
Old 03-13-2011, 03:48 AM
Dembo's Avatar
Petrol isn't expensive enough for you?
Old 03-13-2011, 04:05 AM
s2konroids's Avatar
Do a search on here for similar products, octane boosters etc. You want it for performance/mpg right? In a nutshell 'only if the stock ecu can take advantage of it'.
As dembo says, petrol is expensive enough without adding toluene.
Just stick with vpower which is 99ron, and don't bother with toluene as i doubt over 100ron it will make any difference.
Old 03-13-2011, 04:11 AM
Joeh's Avatar
Read his username
Old 03-13-2011, 04:14 AM
MB
Member
MB's Avatar
Pointless on an NA S2000.
Old 03-13-2011, 05:46 AM
richmc's Avatar
Just stick with Tesco 99 RON, thats enough!
As in Tri-Nitro-Toluine.........AKA TNT!
You could run a can of BK44K through her that will clean the guts out. I use it once a year on the S and used it to advantage on loads of cars.
Old 03-13-2011, 06:48 AM
MB
Member
MB's Avatar
BP Ultimate contains all the cleaning products you need imo.
Old 03-13-2011, 06:51 AM
s2konroids's Avatar
So does persil and cillit bang.
Old 03-13-2011, 07:50 AM
Unlimited Power's Avatar
We do quite a lot of fuel testing for one of the major fuel companies, and also for different race/rally series, and definitely there is horsepower in different blends, and therefore no doubt octane boosters. But unless you i.e. the ECU, can tap into it there's not a lot of point on a road car engine.
Old 03-13-2011, 11:23 AM
haha I see your point, I misread something earlier and thought 25 litres of the stuff was £4.99
It isn't.
I'll stick to tescos.
Quick Reply: toluene
