Trolley jacks
Old Feb 5, 2011 | 11:38 AM
Fontal's Avatar
Default Trolley jacks
I'm about to have my car lowered about 30mm so I'll need to buy a new trolly jack with a low entry just wondering what everyone uses?
Old Feb 5, 2011 | 11:42 AM
Nick Graves's Avatar
Low-entry Sealey 2.5 tonner
http://www.amazon.co.uk/Sealey-2500LE-Trol...n/dp/B001SFXDM8
I estimate it'll cope with a 30mm better than your S will!
Old Feb 5, 2011 | 11:45 AM
martin j's Avatar
You can also use a couple of short planks (1" thick) to run the car wheels up on to increase ground clearance when using the trolley jack
Old Feb 5, 2011 | 11:49 AM
loftust's Avatar
I just used a length of pole to raise the car up mandraulically, then slide the jack in underneath
Old Feb 5, 2011 | 11:53 AM
MB's Avatar
MB
Member
I really need a new jack
My Halfords POS won't fit under the car, so I have to use the OEM jack first. It then makes nasty creaking noises and I am quite concerned about it flipping up in my face, or collapsing and smashing the skirts!
Some long ramps would be nice too.
Old Feb 5, 2011 | 12:17 PM
CHIPPO's Avatar
I have to use bits of timber or the OEM jack to start my trolley off, and my car is standard, well apart from the sag as a result of having me sat in it for 10 years!
Did it today to make getting the sump plug undone easier
Old Feb 5, 2011 | 12:22 PM
RUSS H's Avatar
http://www.machinemart.co.uk/shop/product/...nsmission-jacks
The standard reply.
On the Snap On van yesterday they are doing a Blue Point one but
I think it was over 2 tonne, similar design to the above but a lot lot
bigger and about £199.
Russ.
Old Feb 5, 2011 | 12:25 PM
GaryB's Avatar
http://www.workshopping.co.uk/product/Drap...Facility/45329/
It's the quick lift bit that appeals to me.
I love working on my car but it's a ball ache having to drive it onto paving slabs first.
Old Feb 5, 2011 | 12:27 PM
r8byb's Avatar
Banned
Staggered pieces of wood until it's high enough
Old Feb 5, 2011 | 12:36 PM
Dembo's Avatar
30 half turns with the scissor jack, then I can get the trolley jack underneath.
My Halfords jack is leaking oil, which can't be good. So I really do need to get a new one.
