Valve spring compressor
Old Feb 28, 2024 | 09:38 AM
CHIPPO's Avatar
Default Valve spring compressor
Any one got a device for compressing the valve springs without removing head , bracket thing that bolts to the head once cams are removed ?
Old Feb 28, 2024 | 12:03 PM
Nottm_S2's Avatar
£20 on fleab
https://www.ebay.co.uk/itm/353522076...mis&media=COPY
Whatcha up to?
Old Feb 28, 2024 | 12:09 PM
CHIPPO's Avatar
seen those since I posted , most likely cost more to post both ways lol
New valve stem seals and check retainers maybe replace the inlet retainers if they look at all dodgy.
New plug tube seals and of course check and adjust valve clearances
Old Feb 29, 2024 | 03:39 AM
WallaceS2K's Avatar
That's the type I used: Wallace's S2000 Track/Race car build - Page 12 - S2KI Honda S2000 Forums
Does need a bit of grinding down to clear the injector rail though.
Old Mar 7, 2024 | 02:37 AM
johnckeen's Avatar
How do you stop the valve from dropping if you don't have a compressor?
Old Mar 7, 2024 | 02:53 AM
Irish TuneR's Avatar
Rope method
Old Mar 7, 2024 | 03:56 AM
WallaceS2K's Avatar
Originally Posted by Irish TuneR
Rope method
Yup that's what I did, you can just see it in my link above.
Old Mar 11, 2024 | 05:09 AM
johnckeen's Avatar
you just stuff the cylinder with rope?
Old Mar 11, 2024 | 02:33 PM
noodels's Avatar
would guess add rope and bring up to TDC
Old Mar 13, 2024 | 04:39 AM
WallaceS2K's Avatar
Pretty much, just feed it in through the spark plug hole with the piston at BDC until you can't get anymore in then as Noodels said rotate to TDC and it will compress the rope onto the cylinder head and hold the valves.
booost02
Jul 1, 2013 06:33 PM
ChefJ
Apr 15, 2009 08:46 PM
Turtle
Nov 21, 2007 07:33 PM
honda_f1
Apr 24, 2005 03:49 PM
The Unabageler
Mar 10, 2003 04:37 PM
