Vibration moments
Old 07-28-2004, 06:18 AM
Trip's Avatar
Default Vibration moments
Since last Saturday, I am feeling a vibration on the steering wheel. The vibration increases or decreases relative to the speed of car. The faster I go the more the vibration and vice versa. I tried driving at a constant speed and pressed the clutch pedal. The vibration remained constant to the speed of car. I applied gently the brakes to exclude a warped disk but the vibration always remained the same. I also put down the tyres to 28Psi but to no avail
A said already, the vibration is mostly felt from the steering wheel between around 60Km/H to 160Km/H on straight roads and even the passenger can feel the car vibrating. The feeling isn
Old 07-28-2004, 07:20 AM
Bassoctopus's Avatar
wheel balancing?
Old 07-28-2004, 07:59 AM
Neil.H's Avatar
Originally Posted by neil_s2k,Jul 28 2004, 03:20 PM
wheel balancing?
If it happened suddenly perhaps you lost some wheel weights?
Old 07-28-2004, 08:28 AM
AdrianEagle's Avatar
If you can see a shaking image in your rear view mirror it could be prop shaft out of balance. Relatively unlikely, but having driven RWD cars most of my life it is something that new drivers are possibly not aware of.
Old 07-28-2004, 09:07 AM
S2 Dee's Avatar
Wheel balancing sounds like the culprit as the vibration appears between 60Km/H to 160Km/H this is consistent with a wheel being out of balance! Another possibility is a wheel bearing, also double check the wheels have the correct torque on the nuts! Another possibility is a worn mounting on the engine or drive train. As mentioned before the prop is another area to check.
Good luck.
Old 07-28-2004, 09:13 AM
Trip's Avatar
That is what
Old 07-28-2004, 09:22 AM
Trip's Avatar
Please not the prop shaft or bearings. These sound expensive.
I will unscrew all 4 wheels and make sure they are sitting correctly and use same strength to tighten the nuts.
I will keep you posted with my progress.
Old 07-28-2004, 09:56 AM
S2 Dee's Avatar
Not trying to teach you to suck eggs; so please excuse me for stating the obvious!
Make sure you are using a calibrated torque wrench and ensure that you do a recheck after 24 hours!
I do think your problem is down to a wheel balance issue from what you have writen so don't panic yet!!
Old 07-29-2004, 11:16 AM
mikey k's Avatar
Is wheel nut torque really that critical
Old 07-29-2004, 11:59 AM
S2 Dee's Avatar
No not as the likely cause of the above. Though it is always a good thing to check with a vibration problem. Especially if the wheel has recently been off the car.
Quick Reply: Vibration moments
