Vibrations
Old Aug 31, 2004 | 07:22 AM
slikts2000's Avatar
Default Vibrations
Hi, just wanted to ask if anyone knows why my00 is vibrating every time i come off the gas, if i'm driving normal and i de-acelererate the most annoying rattle vibration happens, could it be the exchaust as it sounds a bit like that...
cheers
Old Aug 31, 2004 | 07:26 AM
GSi's Avatar
GSi
Does it mainly happen at about 3,000-4,500 revs? If so you might want to ask your dealer about the 055 clutch replacement under warranty. It solves the 'buzzing clutch' problem. If you have a warranty that is... if not, don't worry it's not fatal.
Old Aug 31, 2004 | 08:32 AM
slikts2000's Avatar
Not sure what rpm it happens at, i will go and have a spin and update you....
cheers
Old Aug 31, 2004 | 10:04 AM
slikts2000's Avatar
Just been for a spin and yep it happens around that RPM mark, I also drove normal and rested my foot on the clutch pedal and once it got to the RPM i could feel the vibration through the pedal....
I have an extended warrenty as the previous owner had the plugs and oil bolt done, would it be covered by that and what should i noe do... thanks in advance....
Old Aug 31, 2004 | 10:18 AM
GSi's Avatar
GSi
I'd check if you really do have full extended warranty on the whole car, or just the engine (as the oil bolt just extended the engine warranty IIRC). If it's just on the engine then you might want to consider extending the warranty - See posts by Neil_s2k - for
Old Aug 31, 2004 | 10:22 AM
slikts2000's Avatar
I'm gonna get an extended warrenty once this one runs out in feb05 and i'll get it done then if i can, if its not a major problem then it can wait.... many thanks for your input...
Old Sep 17, 2004 | 09:04 AM
slikts2000's Avatar
Got my car booked in on thurs to have the alloys looked at as they have the old corrosion prob, i'm gonna get the boys to take a look at the vibration prob as well, i think its the clutch thing, i've got an extended warrenty from the last owner as he had the plugs and oil bolt done, the cover does say that the engine is totally covered, do you think that it will be or should i wait till next jan once i have bought an extended warrenty from hoda and then have it done......i'm a bit confused about it all.....!!
The honda paperwork says that it is. Hondacare guarantee (HE1)
Old Sep 17, 2004 | 09:13 AM
Bassoctopus's Avatar
This sounds like it's definitely the 054 clutch problem - my first car had it and I know how annoying and loud it can be.
The bad news is that most dealers will not cover this on the extended warranty, and the clutch is around
hoppingdeth
Oct 1, 2007 11:21 AM
andyrees
Dec 22, 2005 01:54 AM
Putney
Jan 2, 2004 07:56 AM
bjl
Dec 28, 2000 08:04 AM
Spectre
Nov 8, 2000 03:31 AM
