weird engine symptoms
Old Feb 18, 2015 | 10:17 AM
vansman's Avatar
Default weird engine symptoms
So been to view an engine to replace my knackered one!
Sounded perfect on idle and perfect above say 1500rpm but it's got a slight knocking/rattling at about 100-200rpm above idle.
So I've left it and said I'll get a second opinion and go back the weekend.
Anything common or is this a tricky one??
Old Feb 18, 2015 | 11:58 PM
User 4225's Avatar
Was it stone cold when you started it and heard it running? F20's do suffer from piston slap when cold due to the fact they're a "forged" engine. Mine sounds a bit rattly at and around idle when it's cold but it's fine once it's warmed up.
Other than that i'd be checking the obvious tell tale things like oil colour and level to get a rough indication of engine care. It may or may not tell you anything but if it's black and grotty looking then it indicates to me that it's probably not been looked after all that well.
Tricky to say without hearing anything though.
Old Feb 19, 2015 | 12:02 AM
MB's Avatar
MB
Member
If it's black it may indicate the oil is doing its job, and if golden it may indicate a fresh oil change to cover something up
I've not heard of piston slap due to it being forged? Only forged part are the Pistons. Timing chain tensions can cause a slight rattle, lots of videos on here for that.
A nock / rattle is not a good sign though.
Old Feb 19, 2015 | 12:19 AM
noodels's Avatar
Probably valve lash clearance
would do a comp test if i was buying
Old Feb 19, 2015 | 12:35 AM
RichwiththeS2000's Avatar
That's also prime time RPM territory for heat shield rattles! Could be something as simple as that, so see if you can isolate where the noise is coming from.
jabbarahm
Dec 7, 2010 01:58 AM
nicholasbartleet
Nov 20, 2009 04:33 AM
zking786
Aug 11, 2007 08:25 AM
alex.stanley
Jul 12, 2005 01:14 PM
Bassoctopus
Apr 20, 2005 10:38 PM
