Weird noise - doesn't seem to be described !
Old Jun 4, 2006 | 12:31 PM
MRmike's Avatar
Default Weird noise - doesn't seem to be described !
Okay my oil levels are absolutely fine, but since fitting the decat i have a noise when the car hits VTEC. It is a very metallic noise, almost like a spoon hitting a metal pipe but at a high frequency, just at the point of VTEC operation, after that the noise subsides (Or the sound of VTEC masks it)
The noise doesn't actually seem to be coming from the engine bay.. I assumed that since I have the HKS dual with no OEM resonator, this noise could well be resonance that has been exacerbated by the decat? Alternatively could the noise be cam tensioner/belt related?
Any thoughts ?? Thanks in advance
Old Jun 4, 2006 | 12:44 PM
MB's Avatar
MB
Member
I hope its not like someone shuffling a box of nails / pins?
MB
Old Jun 4, 2006 | 12:48 PM
MRmike's Avatar
MB
Um..does sound a little like that....
Old Jun 4, 2006 | 12:52 PM
Amuse Boy's Avatar
Pinking?
Old Jun 4, 2006 | 12:53 PM
Amuse Boy's Avatar
Knocking (also called pinking or pinging)
Old Jun 4, 2006 | 01:48 PM
MRmike's Avatar
I'm not sure it is pinking.. why would it occur just at VTEC switchover? Also i presume the F20 has a knock sensor, woudn't the ECU retard ignition advance BEFORE pinking ever occured?
Old Jun 4, 2006 | 02:00 PM
mikey k's Avatar
Doubt it's pinking
Decated HKS's do sound odd though
Easy enough to swap the CAT back and see if it goes.
Are you getting a CEL light?
GWAITE
Sep 15, 2018 04:28 PM
weekendwarrior44
Aug 12, 2017 10:51 PM
SOL1D
Feb 16, 2011 11:42 AM
Surf2k
Sep 14, 2002 02:27 AM
MDS2K
Nov 24, 2001 02:43 PM
