What the hell..
Old Feb 17, 2015 | 01:19 PM
Trunkz's Avatar
Default What the hell..
WTF.. How the hell did two wheel bolts snap clean off?!
Old Feb 17, 2015 | 01:26 PM
Nottm_S2's Avatar
Over tightened?
Old Feb 17, 2015 | 01:31 PM
Trunkz's Avatar
Originally Posted by Nottm_S2
Over tightened?
Far from it, it was loose last time and I had it done at my local garage using a torque wrench. Can you get wheel studs separately or does this require a new hub? I know I'll need to change the wheel bearing (you can't take the hub out without screwing the rear bearing apparently)
Old Feb 17, 2015 | 01:58 PM
Nottm_S2's Avatar
Guess it could've been a while ago and then something has made them fail?
Never replaced one myself, look at the parts diagram on lings.
Old Feb 17, 2015 | 02:05 PM
mikefifth's Avatar
Looks like you lost your nuts, check the mrs hambag.
+1 over tightened, shouldnt be had to fix
Old Feb 17, 2015 | 02:15 PM
japcrap's Avatar
Guess that's no ricky run for you. I think they were overtightened too.
Old Feb 17, 2015 | 05:27 PM
mr-pitts's Avatar
You won't be able to fit studs unless you split the hub
Old Feb 17, 2015 | 10:04 PM
normalbloke's Avatar
Unless you know the history of them all, I'd be looking to change very single one on the car after that!
Old Feb 17, 2015 | 10:48 PM
Trunkz's Avatar
Can wheel studs be purchased from the likes of GSF / Euros or are we looking at a complete hub here?
Old Feb 17, 2015 | 11:18 PM
Mr-T's Avatar
Hmmmm, not good. Got a couple of days to get it fixed before Ricky run!
As mentioned, be worth replacing them all, as if 2 have failed, the others are waiting to fail.
Guess to replace just the studding, you will need to completely pull the hub apart to press them out / in.
Will cost more, but be a lot easier to replace the full assembly.
Give Si from Hendy a shout and see what he can do.
Good Luck and hope you get it sorted!
