What the hell..
Old Feb 17, 2015 | 11:45 PM
Carbon S2K's Avatar
I assume the ARP studs are stronger? If so then you may aswell upgrade
Old Feb 18, 2015 | 01:34 AM
Craig.h's Avatar
I had bolts, not studs, snap on my Clio on track. The cause was they came loose, and I assume the force of the wheel is sitting on the threads rather than the stud itself (the concave mating surface) causing them to snap.
As above I would replace them all, apr do them but I think they may be extended?
Old Feb 18, 2015 | 01:43 AM
MarcS2000's Avatar
what is the recommended torque setting for the S2000 wheel nuts?
Old Feb 18, 2015 | 02:18 AM
BenRNBP's Avatar
80 ft/lbs or 110 Nm
Old Feb 18, 2015 | 06:18 AM
Trunkz's Avatar
Picked up studs from Honda. I'm after a decent make of wheel bearings now. Called around some motor factors and they are mentioning names for ones I haven't heard off.
Old Feb 18, 2015 | 06:20 AM
japcrap's Avatar
SKF is a very good brand if that has been mentioned.
Old Feb 18, 2015 | 06:27 AM
Trunkz's Avatar
Yes I know of SKF. Koyo / NTN are good as well.
Old Feb 18, 2015 | 06:28 AM
Trunkz's Avatar
Found SKF. Crisis averted.
Old Feb 18, 2015 | 06:32 AM
mr-pitts's Avatar
Apr studs are extended, and they are quite expensive.
Old Feb 18, 2015 | 11:32 AM
Trunkz's Avatar
Well these honda studs cost me £25. APR ones are around the £40 mark
