what socket range
Old Jun 18, 2011 | 06:06 AM
S2K-Phil's Avatar
Default what socket range
What is the range of sockets needed to work on the S.
I already have a decent 1/2 inch wrench and extension but my sets are all old money (whitworth/AF etc). I now know that the Dif plug is 23mm so have found this set:
10 -11 - 12 - 13 - 14 - 15 - 16 - 17 - 18 - 19 - 20 - 21 - 22 - 23 - 24 - 27 - 30mm
update - postage is bit rich at £5.95 though
Old Jun 18, 2011 | 06:09 AM
Senna88's Avatar
That'll prob do the trick, except you'll need an 8mm for some bodywork - bumpers I think.
Main ones that Honda use (and always have done AFAIK) is 10mm,12mm,14mm,17mm,19mm. HTH
Old Jun 18, 2011 | 06:36 AM
loftust's Avatar
8mm is required for a few things on the S
FWIW, I'd go for a set that uses 6 sided sockets, especially where the larger sizes are concerned.
Tight bolts + multipoint sockets = rounded off bolt heads
Old Jun 18, 2011 | 07:15 AM
gbduo's Avatar
If you can stretch to £100, Halfords do a socket set normally on half price which is 160 pc and includes imperial, metric sockets and combination spanners/ratchet spanners,plus allen keys and drive attachments. It is a quality bit of kit.
I think it is Halfords Advanced 160 Pc socket set or something.
Old Jun 18, 2011 | 08:18 AM
S2K-Phil's Avatar
thanks for the advice
gbduo - decided £100 too expensive as I have loads of tools so many in the toolkit would be duplicates. It would be nice to have a nice new shiny kit though. Thanks for the thought.
Loftus - point taken on the 6 not 12 facets. 6 it'll be.
senna88 - I0-19 range is a cheaper option and will get the odd socket outside the range if needed. I have a decent set of rings anyway and have an old 3/8inch part set (lent bits to friends in the past) with a few odd sockets which I think will cover the 8mm requirement.
Old Jun 18, 2011 | 08:19 AM
loftust's Avatar
It's 150 piece for £100...I bought myself one recently after I went in to buy something completely different
Lifetime warranty too...just keep that receipt!
Old Jun 18, 2011 | 10:23 AM
Ginge's Avatar
If you are looking for a set of sockets then see if you can find some "wall drive" sockets, they have six sides but instead of flat sides that drive the corners of the nuts they have a sort of cam shaped sides that drive the flat parts of the nuts, they can take a lot more torque than six sided or 12 sided sockets.
http://www.thesitebox.com/sealey/soc...-seaak857.aspx
Pricey but really good.
Old Jun 18, 2011 | 10:31 AM
gt750boy's Avatar
Banned
As with all things, but especially with tools. buy cheap and buy twice. You should always buy the best quality tools you can afford, so look for names like Mac, Snap-On, Crescent, or Craftsman (Sear's own brand). Your nuts will appreciate it.
Old Jun 18, 2011 | 10:33 AM
loftust's Avatar
FWIW, Halfords professional range are very good quality
Old Jun 20, 2011 | 01:38 PM
martin j's Avatar
If you can get someone with a halfords trade card you may be able to save some readies.?
windhund116
Aug 5, 2015 05:43 AM
ProV1
Jun 21, 2006 12:19 PM
Ks320
May 19, 2006 10:18 AM
Spoonie
Mar 4, 2006 07:40 AM
chris_barry
Oct 30, 2003 09:28 PM
