Where to buy exhaust system gaskets?
I have a tanabe cat-back exhaust and there are 3 gaskets in the system that were all broken and blowing heavily. Whats a good source for gaskets for aftermarket exhaust.
I need the 'triangle' 3 bolt hole gasket between the cat and the exhaust. A ~60mm gasket with 2 bolt holes and 2 ~40mm gaskets with 2 bolt holes.
Any pointers appreciated.
Thanks,
Matt
Thanks,
Matt
I agree with Bozwell I was on the look out for one for my decat, I just used paste 6 month ago and it's still fine no blowing - let it set correctly. According to some folk on here it would of failed by now
If you clout the pipe then it probably will fall out
Get exhaust some gasket sheet from eBay.
Lay over flange and knock around edges and holes with ball pein hammer.
Or draw around and cut/punch out.
Smear a little copper grease for re-usability and bolt up.
Steve.
Steve.
Steve.
Steve.
Easy and cheap.
gaskets are ok in a road car but in a competition car i wouldn't bother. if the exhaust flanges are nice and flat they will pretty much seal themselves anyway.
if they are not flat that is why the gaskets blow out.
I tried a repair with paste and it failed. I'll give it a go with just paste and see what happens. Otherwise I'll give the gasket material a whirl.
I did find this which looks good except for the prices - http://www.blitz-uk.co.uk/Product-14.aspx
Iil-dik
06-22-2012 01:57 PM
MugenRioS2k
10-28-2009 08:08 PM
S2KEvolution
12-17-2003 06:10 PM
