Whining Noise!
Old Sep 14, 2012 | 04:18 AM
kaioshi's Avatar
Default Whining Noise!
HI all i have a whining noise and this time not from the misses! My 02 S2000 between 45 and 70mph gives off a whining noise mainly heard when the roof is up of course.
It is not overly loud and does sound like prop or something in gearbox. I have just had a recent diff fluid and gearbox fluid change and this did not cure it.
Also notice when the clutch is released on idle there is a bearing noise but when pressed it goes away.
Any thoughts?
Old Sep 14, 2012 | 05:56 AM
Bandit_287's Avatar
Bearing noise with the clutch released is normal, its the clutch release bearing and they all do that. The whining noise sounds a bit more serious though, either the diff is on it's way out or maybe a bearing in the gearbox. Get it along to a specialist for diagnosis.
Old Sep 14, 2012 | 08:47 AM
kaner's Avatar
I had a whining noise on MY00 S2000 at the same speeds as yours and thought that was coming from the transmission or diff. I took it to a local specialist and it turned out to be a wheel bearing, which has now been changed and all is good.
Old Sep 14, 2012 | 03:53 PM
Mans Best's Avatar
Have you used the right diff oil? My friendly local Honda dealer didn't and my diff was wrecked in just a few miles
of course, they denied it!
Old Sep 15, 2012 | 12:35 PM
kaioshi's Avatar
The garage did use the correct oil as they were shocked as the costs of the it.
I was hoping it would be a wheel bearing and nothing major on the drieve train.
Will strip down the rears in the week and take a look.
Anyone recommend a specialist that i could take it too in or around the Northamptonshire area?
Old Sep 15, 2012 | 01:07 PM
Si2k's Avatar
Could be gearbox secondary shaft bearings. They run a little dry on the S2000s and start to whine. As it gets worse it will sound like a rubbing brake. You will notic it next to concrete motorway barriers
polar2k
Jul 15, 2014 08:20 PM
KyungMin
Feb 13, 2014 04:13 PM
s2k_atif
Jul 8, 2007 02:30 AM
Cycloneranga
Jan 7, 2007 12:16 PM
millertown15
Jan 12, 2006 09:44 PM
