Noise in Transmission? Anyone else have it?
Old Jan 8, 2006 | 10:23 PM
millertown15's Avatar
Default Noise in Transmission? Anyone else have it?
I understand that in some cars with the clutch released in neutral you can hear the throw out bearing slightly. Maybe im being paranoid but I dont think I noticed it in my s2k before. Anyone else hear slight transmission noise when they let out the clutch in neutral??? Thanks.
Old Jan 11, 2006 | 07:00 PM
Thanks for the help guys????? haha jk
anyone know???
Old Jan 11, 2006 | 07:03 PM
BOYRACER1684's Avatar
its the diff, mine just blew and the dealer told me that noise was nothing to worry about. Take it to your dealer, document your visits and make sure they fix the problem because if it is your diff and it does let out they will raise hell in order to cover it under the warranty.
Old Jan 11, 2006 | 09:14 PM
rworne's Avatar
Assuming the car is in neutral and not moving, I fail to see how the diff comes into it.
Mine has a weird rattle around 4500 RPM under load. The engine speed just sets up some harmonic somewhere and it drives me nuts. It's done that since new and I suspect it's either the clutch (doubtful) or some heat shield or exhaust rattle (most likely).
Old Jan 12, 2006 | 05:09 AM
efinguy85's Avatar
i have the same problem and it makes me very angry on the inside...but i was told that 00 adn 01 s2000 r known for it
Old Jan 12, 2006 | 05:12 AM
passmans2kny's Avatar
i had that once i installed my exhaust, it was the exhaust heat sheild rubbing the exhaust, it sounded a lot worse than what the actual problem was.
Old Jan 12, 2006 | 09:26 PM
Yeah its not the differential. but it just worries me. Gotta change the fluid anyways maybe that will help, what is used in the tranny and differential????
Old Jan 12, 2006 | 09:44 PM
BlackJoker's Avatar
I have that problem, too. I took it to the dealer and he told me it was the throw out bearing. I'm going to get a 30k service tomorrow so I'm gonna ask the mechanic that I trust this time.
kaioshi
Sep 15, 2012 01:07 PM
JEEBS
Aug 15, 2011 02:57 PM
DJSang
Dec 6, 2007 07:26 AM
BlueS2000Boy
Oct 10, 2003 08:01 AM
EclipseGuy
Sep 16, 2003 04:38 PM
